Thread Number: 16113
Filter Queen motor bearings |
Post# 171775   3/3/2012 at 17:08 (4,408 days old) by d-jones (Pittsburgh)   |   | |
Does anyone here know the part number for the model 33 motor bearings. I've got a bad lower bearing and I'd hate to have to replace the entire motor over such a small part. |
Post# 171817 , Reply# 1   3/4/2012 at 01:31 (4,407 days old) by hoover28 (Oneida N.Y.)   |   | |
it's a 8mm bearing. you can get it at most vacuum shops or a hard ware store. should be under 12.00 just take the old one with you wan you go to get it. Chris |
Post# 171890 , Reply# 2   3/4/2012 at 18:22 (4,407 days old) by reo580 (Holland, Michigan)   |   | |
Make sure you seat it properly.
I used a long socket that fit precisely on the inner race(the inner circle that contacts the armature shaft). be gentle with the fans when you are putting it together. When I do FQ motor repairs I have a rule,(maybe a little OCD) I check the fans three times before I do my final tightening. |
