Thread Number: 15985
Eureka 1934B Attachment Set, does it work on these. |
Post# 170483 , Reply# 3   2/22/2012 at 12:18 (4,444 days old) by kloveland (Tulsa)   |   | |
The suction power on the Eureka with the converter will probably be the same as your little Dirt Devil hand vac. Personally, I have no problem with the attachment kit for the Hoover Convertible or Eureka Uprights. They have plenty of power for dusting. But I wouldn't recommend it for deep cleaning upholstery. It really depends on your individual situation and the items you are trying to clean.
A standard Eureka upright attachment set will work on your 1934B. Had one myself awhile back. The 1934B uses the same rug plate, so you shouldn't have a problem using the converter. |
Post# 170519 , Reply# 4   2/22/2012 at 14:47 (4,444 days old) by eurekaprince (Montreal, Canada)   |   | |
You need the Eureka Model 60D attachment set - see the eBay item below.
It actually is fine for light dusting - I had a set with my Dial-A-Nap upright which had a weaker motor than your Boss. I even added an extra floor brush and plastic wand which did not do a bad job on floors. But these tools could never replace a proper canister vac - so much easier to drag around than an upright with a wheeled pan converter.... CLICK HERE TO GO TO eurekaprince's LINK on eBay |
Post# 170527 , Reply# 5   2/22/2012 at 16:21 (4,444 days old) by eurekaprince (Montreal, Canada)   |   | |
Post# 170532 , Reply# 7   2/22/2012 at 16:42 (4,444 days old) by vacuumfreak (Ontario, Canada)   |   | |
Sorry for the poor quality picture above. Just letting you know it works just like the converter pan on some of the Convertibles, although I'm not quite sure it gets the same amount of suction as them. |
Post# 170540 , Reply# 8   2/22/2012 at 17:54 (4,444 days old) by fan-of-fans (USA)   |   | |
