Thread Number: 15865
Eureka Bag not Inflating, and other problem |
Post# 169038 , Reply# 1   2/9/2012 at 21:50 (4,457 days old) by eurekaprince (Montreal, Canada)   |   | |
Eureka fan-first upright bags often do not inflate when you have installed a new, empty F&G bag. The airflow is quite clean at that starting point, and so there is not enough pressure on the paper material to blow it up like a balloon. Give it a few uses, and as the bag fills a bit with dirt and dust and carpet fibres, the airflow begins to reduce and the bag will blow up nice and full!
Not sure where the ball bearings are coming from though.... :-) |
Post# 169040 , Reply# 2   2/9/2012 at 21:54 (4,457 days old) by eurekaprince (Montreal, Canada)   |   | |
Most important part of this bit of "vacuum science": Eureka top fill F&G upright bags allow the dirt to drop from the top of the bag. So when a fresh one is used, the dirt drops away from the airpath and the air flows out through the top part of the bag. It's only really when the bag pores start to close up, that the bag starts to really inflate like a balloon...
Post# 169042 , Reply# 3   2/9/2012 at 21:57 (4,457 days old) by TheBillbot ()   |   | |
Ah ok, thanks, I rarely use it, my 1934B Is my Daily Driver. |
Post# 169072 , Reply# 4   2/10/2012 at 07:10 (4,456 days old) by eurekaprince (Montreal, Canada)   |   | |
You're welcome!
One other thing: make sure you have installed the F&G bag correctly and followed the instructions on the bag. Installing the bag with the intake tube facing the zipper and the collection sack facing the handle is a common error and can block the movement of air and dirt. Make sure you always install the bag with the intake tube facing the handle and the collection sac facing the zipper of the outer bag. Have a great weekend! Eurekaprince Brian |
