Thread Number: 15756
Windtunnel Brush Roll Control |
Post# 167804 , Reply# 1   1/30/2012 at 21:58 (4,468 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
Hi Joe
I have this problem with the Vax Mach Air - based on the Hoover Windtunnel Air - and if it uses existing floor head design like your older model then the reason the brush roll still spins when the machine is tilted is because there may be a button on the front of the floor head that gets pushed in whenever the base of the main dust bin meets the floor head when the vacuum is put back into the upright position/left standing. When the vacuum is tilted, the mechanism will pop up because the vacuum doesn't actually lock down to the upright position when tilted but raises slightly. Hope all of that makes sense! It is an issue that I noticed straight away with my Mach Air. |
Post# 167867 , Reply# 2   1/31/2012 at 16:11 (4,467 days old) by kloveland (Tulsa)   |   | |
If so, your belts may need to be replaced. Check your V belt and flat belt. A woman from work had me look at her Self Propelled Windtunnel the brush would stop when it hit the carpet, like yours. I replaced both belts and it ran like new.
Below is a link to the manual. CLICK HERE TO GO TO kloveland's LINK |
