Thread Number: 15472
Kirby G4 Transmission
Post# 164443   1/3/2012 at 08:05 (4,487 days old) by jakesvacs ()
Hey,
In neutral my kirby g4 clicks when being moved back and forth? What causes this and is it broken?
Post# 164489 , Reply# 1   1/3/2012 at 14:43 (4,486 days old) by djtaylor (Salt Lake City, Utah)
Check the Cam Bracket...
djtaylor's profile picture
Sounds to me like the Cam Bracket needs to be replaced. The Cam Bracket is the little part that pushes the gears apart when the peddle goes from Off to On. It wares down over time. If you take the transmission out for the base unit, you unscrew the control peddle and as you remove the peddle the Cam Bracket is on the peddle. It sits loosely, so it is easy to replace. You can get one on eBay fairly easily.
Justin
Post# 164492 , Reply# 2   1/3/2012 at 14:55 (4,486 days old) by jakesvacs ()
Thank you very much! Know who to ask kirby questions about now! I thought it would be something much more majour, but seams easy to replace!
Thanks again,
Jake
