Thread Number: 15422
Lets see 'em! |
Post# 163896   12/30/2011 at 18:12 (4,499 days old) by jmurray01 (Scotland)   |   | |
Post# 163917 , Reply# 1   12/30/2011 at 19:00 (4,498 days old) by juniorsenior ()   |   | |
I forgot to say i maintain 11 Henry,s and a Charles in my work here is one of them, they are all 110v versions |
Post# 163954 , Reply# 2   12/31/2011 at 05:49 (4,498 days old) by jmurray01 (Scotland)   |   | |
Post# 163955 , Reply# 3   12/31/2011 at 05:59 (4,498 days old) by juniorsenior ()   |   | |
The plugs on them are different because they are 110volt versions. None of ours use the bags or the attachments just the hose you see in the photo. |
Post# 163957 , Reply# 4   12/31/2011 at 06:01 (4,498 days old) by jmurray01 (Scotland)   |   | |
Post# 163958 , Reply# 5   12/31/2011 at 06:20 (4,498 days old) by 1926700 ()   |   | |
heres one side of my vacuum room |
Post# 163959 , Reply# 6   12/31/2011 at 06:21 (4,498 days old) by 1926700 ()   |   | |
another side... |
Post# 163960 , Reply# 7   12/31/2011 at 06:22 (4,498 days old) by 1926700 ()   |   | |
for good mesure....earley 28 through 62 |
Post# 163961 , Reply# 8   12/31/2011 at 06:23 (4,498 days old) by 1926700 ()   |   | |
29, 61, 62, 63 |
Post# 163962 , Reply# 9   12/31/2011 at 06:25 (4,498 days old) by 1926700 ()   |   | |
some DAM's |
Post# 163963 , Reply# 10   12/31/2011 at 06:25 (4,498 days old) by 1926700 ()   |   | |
power drive DAM's |
Post# 163965 , Reply# 12   12/31/2011 at 06:29 (4,498 days old) by 1926700 ()   |   | |
and the corner of my cannister room.... |
Post# 163977 , Reply# 13   12/31/2011 at 08:45 (4,498 days old) by juniorsenior ()   |   | |
@ Jamie The reason they are 110v is that certain places of work require for health and safety that they use a lower voltage to minimise the risk of serious electric shock. |
Post# 163997 , Reply# 14   12/31/2011 at 09:19 (4,498 days old) by jmurray01 (Scotland)   |   | |
Post# 164009 , Reply# 15   12/31/2011 at 10:01 (4,498 days old) by collector2 (Moose Jaw, Sk)   |   | |
Hey Jamie - Wattage is calculated by amperage drawn multiplied by voltage Eg a 660 Watt motor designed to run on 220 Volts draws 3 amps while the same 660 Watt motor designed to run on 110Volts draws 6 amps. Its just a matter of using the appropriate motor for the voltage supplied. Usually the models all have the same Wattage motor, just designed for the Voltage they are required to use.
