Thread Number: 15271
What is the point of the tool setting ? |
Post# 162169   12/15/2011 at 06:14 (4,509 days old) by jmurray01 (Scotland)   |   | |
I've been wondering this lately.
My 1994 HOOVER Turbopower 1000 (Model number: U2812) has a tool setting on the height adjustment scale (thin pile, medium pile, thick pile, extra thick pile/tools), but when the cleaner is in the upright position, putting it in the tool setting doesn't change the height. The only difference it makes is when the cleaner is in use, which it obviously isn't going to be when I'm using the hose pipe. So, why is it there if it is a useless feature ? My 1993 Philips U800 has a tool setting too, but its one is useful, because it isn't the type of cleaner that raises the brush roll from the ground when put in the upright position, so it does require a tool setting. But I can't understand what the tool setting on the HOOVER is for! |
Post# 162174 , Reply# 1   12/15/2011 at 07:05 (4,509 days old) by vinvac (Dubuque IA)   |   | |
Post# 162175 , Reply# 2   12/15/2011 at 07:17 (4,509 days old) by jmurray01 (Scotland)   |   | |
Post# 162198 , Reply# 3   12/15/2011 at 08:54 (4,509 days old) by fan-of-fans (USA)   |   | |
I think it mainly was do divert the suction to the tools, at least it was on the ones here (USA).
On the lower end Hoovers with onboard tools (such as the Elite), you inserted the hose into the tool door when you wanted to use it. The end you inserted in had a built in diverter that closed off the suction to the brushroll. However on the higher end models such as the Legacy (which I had) and the PowerMax, there was a "permanent" hose. It did not have a diverter on the end, but you inserted the hose into the tool port, turned it to lock it and then left it in place, whether you were using the hose or not. When you slid the height adjustment to "Cleaning Tools" it slid a diverter door to shut off the suction to the brushroll. Though I don't believe it did anything else as far as height adjustment and I know it didn't shut off the brushroll. So that's why the Elite and lower end Hoovers didn't have a "Cleaning Tools" setting, it did the same thing basically when you inserted the hose. |
Post# 162200 , Reply# 4   12/15/2011 at 09:40 (4,509 days old) by jakesvacs ()   |   | |
setting... On your model turbopower it is simply to raise the brushrbar higher off the carpet so it doesnt damage it. On older turbopowers this was to divert the suction to the hose. |
Post# 162263 , Reply# 5   12/15/2011 at 21:20 (4,509 days old) by eluxomarty (Palm Springs)   |   | |
fan-of-fans has the best explaination for the "tools" setting on those particular vacuums. |
Post# 162390 , Reply# 7   12/17/2011 at 05:25 (4,507 days old) by jakesvacs ()   |   | |
I had a turbopower 2 in red for a very long time and used it non stop. On tool setting i thought it did naff all or simply raise it higher. I knew it was a clean air vac too. |
Post# 162399 , Reply# 8   12/17/2011 at 09:04 (4,507 days old) by jmurray01 (Scotland)   |   | |
Post# 162886 , Reply# 9   12/20/2011 at 19:17 (4,504 days old) by Rolls_rapide (-)   |   | |
Correct. The highest height setting acts as insurance against failure. I wonder how many folk never bothered with that particular instruction? |
Post# 163040 , Reply# 10   12/21/2011 at 15:30 (4,503 days old) by jmurray01 (Scotland)   |   | |
Post# 163041 , Reply# 11   12/21/2011 at 15:30 (4,503 days old) by jmurray01 (Scotland)   |   | |
Post# 163050 , Reply# 12   12/21/2011 at 17:25 (4,503 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
I disagree.
The manual or newer electronic handbrake may seem like an unnecessary throwback to an earlier era but in fact, when you leave a manual or automatic transmission in park (or first gear) you are putting a big strain on the gear shift pawls & teeth should there be any incline where the car rests or god forbid, a bump from ahead or behind. Yes, it does hold the car from rolling but at what eventual cost? The handbrake on the other hand is expressly designed and retained for this purpose - to activate friction brake pads on the rear wheel hubs or the drive-shaft and it is this which keeps the car from rolling. Folks say 'but the handbrake keeps slipping' That's because it is not used regularly and the cables stretch. Having your axillary brake shoes and cables inspected and adjusted should be a standard practice whenever your wheels are rotated. Jiffy Lube does. Every Owners Manual I've ever read instructs to apply the handbrake whenever the car is parked, although it is no longer explained why. I choose to not second guess the engineers that design these complicated machines. Another silly thing that can shorten the life of a transmission in an automatic or manual - and does, ask any transmission mechanic - is, when backing out of a driveway or parking slot, is to to NOT come to a complete stop before engaging Drive. These are habits that should be taught in Driver Training Schools. But hey, a car is not a vacuum and it's your investment... Dave, makes a habit reflex to apply the handbrake in Neutral before shifting past Reverse in to Park. Always have, always will. |
Post# 163081 , Reply# 14   12/22/2011 at 00:26 (4,502 days old) by jmurray01 (Scotland)   |   | |
