Thread Number: 15202
Help with Kirby Heritage |
Post# 161447   12/7/2011 at 22:31 (4,522 days old) by motojoejo (MO)   |   | |
I'm trying to replace a damaged hood on a Kirby Heritage with a new hood. What the best and easiest method for removing and replacing the hinge pin? |
Post# 161488 , Reply# 2   12/8/2011 at 16:15 (4,521 days old) by motojoejo (MO)   |   | |
Thank you so much for the help. I'm not seeing the clip/spring to remove. Which side it is located? |
Post# 161500 , Reply# 4   12/8/2011 at 20:16 (4,521 days old) by eurekastar (Amarillo, Texas)   |   | |
The hinge pin in a Heritage is a piece of rolled aluminum. You'll need a long punch pin that is the diameter of the pin so you can drive it all the way through. Be very care full or you'll bust one of the lugs or even crack the fan case. It takes a little finessing to get everything leveraged just right, but you can do it!
CLICK HERE TO GO TO eurekastar's LINK |
