Thread Number: 15186
Convertible tool door |
Post# 161210   12/5/2011 at 14:38 (4,497 days old) by kloveland (Tulsa)   |   | |
My 589 and some of my other convertibles have a cracked tool door. The door has trouble staying shut and leaks suction. I suppose I could just try and glue it shut. Since I hardly use the rear conversion tools; the front conversion “power seal” tools provide more suction even on the older metal based convertibles.
I can imagine that was a pretty common problem back in day, for the tool diverter door to break on the metal based convertibles. |
Post# 161281 , Reply# 1   12/6/2011 at 00:09 (4,497 days old) by pnluxconvlvr (Georgia)   |   | |
I went through the same thing growing up. I ended up reinforcing the back side of the door with vinyl electrical tape and then putting a small bead of clear silicone around the backside edge and it did a good job of securing a crack in the door and not leaking. I used graphite on the spring after cleaning it with WD40. I did have to check on occasion to make sure the door was closed tight. Just a couple thoughts. Convertibles forever! :)
Post# 161424 , Reply# 2   12/7/2011 at 14:56 (4,495 days old) by kloveland (Tulsa)   |   | |
