Thread Number: 15128
Two Kirby 561 handles, is one a replacement? |
Post# 160494   11/28/2011 at 23:23 (4,525 days old) by Northwesty (Renton, WA)   |   | |
These two handles, or rather the shafts, are both on Kirby 561s, but this one is smooth... |
Post# 160495 , Reply# 1   11/28/2011 at 23:25 (4,525 days old) by Northwesty (Renton, WA)   |   | |
While this one has ridges. I have another Kirby with this type of pattern on the handle shaft though it is different than this one. |
Post# 160501 , Reply# 2   11/28/2011 at 23:43 (4,525 days old) by twocvbloke ()   |   | |
Seems you have Bojack Frankenkirbys to me, the ribbed handle I think came from earlier 500 models, and the smooth one from later models... |
Post# 160516 , Reply# 3   11/29/2011 at 00:21 (4,525 days old) by lunchboxsean ()   |   | |
The first one is a replacement. You can tell by how far it goes down. |
Post# 160549 , Reply# 4   11/29/2011 at 10:16 (4,525 days old) by kirbyvacuum (Long Island New York)   |   | |
Hi All I have a Kirby 561 it has the ribbed handle Doug |
Post# 160578 , Reply# 5   11/29/2011 at 17:24 (4,525 days old) by vac_whisperer ()   |   | |
Post# 160579 , Reply# 6   11/29/2011 at 17:26 (4,525 days old) by vac_whisperer ()   |   | |
The first one is a replacement, because, like Sean said, you can tell by how far it goes down. And the ribbed handle was used al the way up to the D50, which was the last irby to have the "Stick" type handle. |
Post# 160584 , Reply# 7   11/29/2011 at 19:28 (4,525 days old) by ralph (Morgan Hill)   |   | |
If you search for electrolux~137’s Kirby 500 series history you will see that the 509 was the last model that had the smooth wand and the 510 was the first model that had the ribbed wand. |
Post# 160591 , Reply# 8   11/29/2011 at 20:51 (4,525 days old) by Northwesty (Renton, WA)   |   | |
For the information. But it sounds like the older Kirbys had the smooth wand and then were followed by the ridged ones? 509/510. |
Post# 160593 , Reply# 9   11/29/2011 at 21:29 (4,524 days old) by vac_whisperer ()   |   | |
Rigid ones came somewhat later, the smooth ones were on anything up to about the 510. |
Post# 160711 , Reply# 10   11/30/2011 at 20:35 (4,524 days old) by broomvac (N/A)   |   | |
Post# 160717 , Reply# 11   11/30/2011 at 21:02 (4,524 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 160763 , Reply# 12   12/1/2011 at 04:40 (4,523 days old) by kirbymodel2c (Nottingham, England)   |   | |
Hi, The mid section of the handle was smooth/plain up to the Kirby 517.
As it say on Mr Lesters site under the Kirby 500 series section 517/518/519... "Middle (longest) section of handle became ribbed, not plain, metal tube. First rib design had the ribbing spaced about 1/8" apart and rather fine -- not very deep. Later, the ribbing becomes deeper and spaced much, much closer together -- (and that same style was used until the hideous-green Sanitronic D-80 came out, when a new plastic handle was introduced)." Hope this helps. James:o) |
