Thread Number: 14868
Electrolux Model G |
Post# 157757   11/1/2011 at 19:02 (4,551 days old) by bagintheback (Flagstaff, Arizona)   |   | |
Over the weekend I found my third thrift store Electrolux, this time a model G. It came with the original hose and the carpet/floor tool. It's super quiet and polished up nicely, but I have a few questions.
How strong should the suction be on this model? I need to get a new bag for it, but even without the hose the suction is not impressive. I tried the rug tool on my Dyson today, and I was not impressed. I have no idea how anyone could clean with such low suction. Maybe my standards are too high after only using 9-12amp motors? The suction is a little less than what I get with my Kirby Heritage II Also, when I put my hand over the intake, the vacuum makes a squealing sound as if it was leaking air. The bag the vacuum came with is slightly bent, so maybe this is the cause? Why is it all used Electroluxs need so much maintenance?! I hope I can get it working well; I would like to see why everybody loves these Model Gs. Nathaniel |
Post# 157763 , Reply# 1   11/1/2011 at 19:46 (4,551 days old) by cleaningbuff (Quincy, IL)   |   | |
Post# 157768 , Reply# 2   11/1/2011 at 20:39 (4,551 days old) by Floor-A-Matic (somewhere)   |   | |
The rubber gasket (around the pipe that goes into the bag opening) may need to be replaced. |
Post# 157774 , Reply# 3   11/1/2011 at 22:53 (4,551 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Some aftermarket Lux bags are made with a thinner cardboard that doesn't always seal tight against the gasket with the door closed. Fine when the bag is new but the problem there is that over time - as our collector vacs tend to sit - the cardboard dishes inward allowing air to be drawn in around the gasket seal, which could cause a squeal.
More likely the squeal is coming from the motor's rubber mount ring. Sounds to me like the fans are possibly clogged with dustbunny poo accumulation and/or the rubber gasket surrounding and sealing the motor is cracked or split or slipped off the motor mount flange, letting airflow bypass the fans. The squeal comes from the split edges vibrating against one another like a pair of lips. With the inlet blocked air is drawn forward from the backside of the motor through the gasket, back through the fans...and so on... This is a relatively easy condition to correct if you're comfortable taking the machine apart to diagnose the problem and carefully execute the repair. A G, measured at the inlet without a hose, pulls between 60" and 65" when all seals are intact and tight. The round rubber gasket around the inlet that goes into the bag opening is flared like a trumpet bell and I have yet to see one that was flattened or deteriorated that it had lost its flexibility or sealing properties. It is under very little pressure against the bag cardboard. It's function is to , yes, prevent airflow leaking in around the bag door seam but the bag itself has an additional very snug rubber 'condom' membrane seal around the inlet pipe. It would be the LAST thing I would suspect in your described situation. Dave |
Post# 157809 , Reply# 6   11/2/2011 at 17:33 (4,550 days old) by bagintheback (Flagstaff, Arizona)   |   | |
Thanks to everyone who has responded. I will try a new bag and see if that fixes my problems. I sure hope it is not a gasket problem, as I do not want to open the vacuum up unless I absolutely have to.
Real1: I have the turquoise model, and what I meant by the maintenance comment is that all of the used electroluxs I've seen are never in usable shape. The hose leaks or the gasket is bad or something that prevents me from cleaning with it. They are simple repairs, but I'd much rather have an older Hoover or Eureka where I can take it apart and fix in minutes. I'm not a canister person anyway. |
Post# 157885 , Reply# 9   11/3/2011 at 07:09 (4,550 days old) by redgeminipa (Altoona, PA)   |   | |
Another view |
Post# 157886 , Reply# 10   11/3/2011 at 07:10 (4,550 days old) by redgeminipa (Altoona, PA)   |   | |
Inside, and we didn't clean it... |
