Thread Number: 14376
ok... Myyy Monstervac. |
Post# 151772   9/18/2011 at 01:51 (4,596 days old) by beerad (Beautiful Vancouver BC)   |   | |
And hereee it iz ... two Filter Queens. Wow.. is this thing powerful! I will be posting a youtube vid as well. |
Post# 151776 , Reply# 1   9/18/2011 at 02:15 (4,596 days old) by gsheen (Cape Town South Africa)   |   | |
Post# 151877 , Reply# 2   9/18/2011 at 10:11 (4,595 days old) by goadie12 ()   |   | |
I can only imagine I bet it has the same amount of power as some central vacs. Zach |
Post# 151882 , Reply# 4   9/18/2011 at 11:09 (4,595 days old) by gsheen (Cape Town South Africa)   |   | |
If you hook up two motors like you guys both have it is air parralel you will get more airflow but as their is more airflow you will loose some lift ( suction)
It also has to do with friction, the longer the hose the more airflow you will loose in friction. I am not familiar with the USA electroluxes but if they have a blowing port you could technically put the suction hose from one machine into the other machines blowing port. this would give you more suction like having 4 fans on one motor, this type of system is used on most portable carpet cleaners as you need lift to get the water out of the carpet. industrial tangental motors ( ones with the exhaust are designed for this with seperate cooling fans for the motor, with the thru flow motors used in mst domestic vacuums you could nd up overheating the motor.This would give you twice the lift but reduce you airflow by as much as half |
Post# 151923 , Reply# 5   9/18/2011 at 15:06 (4,595 days old) by beerad (Beautiful Vancouver BC)   |   | |
I felt the airflow and suction at the y pipe and indeed it is veryy powerful.. it feels like there is more suction than a central. |
Post# 151927 , Reply# 6   9/18/2011 at 15:24 (4,595 days old) by gsheen (Cape Town South Africa)   |   | |
there should be a bit more suction than a central vac , remember a central vac looses some of its power thru frictiondue to the long hoses and internal pipe work , thats why they use those huge motors. 2inch hose would also help improve the suction , less friction.
When I owned my carpet cleaning company I built a truck mount using 4 amatek big boy motors , the same found on many central vacs , two in air parralel and the other two hooked up to the first two in series, that machine crushed a 50 gal drum I was using as a vac tank , I had to get a re inforced one made. |
Post# 151929 , Reply# 7   9/18/2011 at 15:33 (4,595 days old) by vacman117 (Chicago, IL)   |   | |
Post# 151957 , Reply# 8   9/18/2011 at 17:20 (4,595 days old) by beerad (Beautiful Vancouver BC)   |   | |
I have had this idea perculating in my imagination for the past two years.... I felt very inspred to take action on it....Now i will work on perfecting it... soo stay tuned.... thanks for your sharing.. Brad. |
Post# 151960 , Reply# 9   9/18/2011 at 17:29 (4,595 days old) by gsheen (Cape Town South Africa)   |   | |
Brad
just make sure the two machines are in similar condition , if one motor is weaker than the other the stronger motor will pull the weaker one making in spin faster than it should and prematurly killing it, talking from expeariance here.
I used to work in the r&d motor department for a vacuum company so I got paid to blow motors up, what a job. I learnt a thing or two there. I once built a vac tank with 5 motors on it for an experiment. bloody noisy.
Have fun
Gareth |
