Thread Number: 13788
Other than duct tape? |
Post# 146172   8/7/2011 at 13:44 (4,644 days old) by shag (Ontario, Canada)   |   | |
Post# 146175 , Reply# 1   8/7/2011 at 14:01 (4,644 days old) by twocvbloke ()   |   | |
Stuff like this perhaps?: CLICK HERE TO GO TO twocvbloke's LINK |
Post# 146255 , Reply# 7   8/7/2011 at 22:01 (4,643 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Kenmore's supplier/builder pulled a real boner with this hose which has rendered most Kenmores of this era essentially useless. Compounding the problem is the variations in hose end electrical connections that are incompatible with each other across the model line year to year.
Exclusive to Sears Kenmore apparently, I have not seen this particular lateral splitting on any other maker's hoses. But it is the most common condition you'll find on secondhand Kenmores - even the replacement hoses do this after a time. The hoses are noticeably stiffer and less flexible than one would expect, right out of the shipping carton. The double coils make them heavy. The problem stems from the too-much-clay/vinyl mix extruded too tightly over the double excessively heavy stiff gauge wire coil and the visible lateral striations formed by the extrusion die. There's really no point trying to tape it up attractively as fresh new splits will appear before you're done. The best you can do is tape it and use it until it falls apart. Meantime keep your eyes peeled for some other electric hose and perform a hose end transplant. Also not the easiest thing to do because the Kenmore ends do not open along seam lines - they are totally molded in place and the fittings are 'proprietary' at the swivel intake end. I'm not precisely sure when these hoses were introduced (early 70s?) but I always see them on the white rounded compact tool-under-the-lid versions with the printing silkscreened in red beside a large 3 digit model number. When the coloured plastic larger Whispertone models came out a newer better colour-matched hose was supplied. It's a gosh-darn shame since these smaller compact 'bean' Kenmores and their power nozzles are quite good. I have several of them and only one has an intact hose. Interestingly, they are molded from white plastic but every one I've seen has yellowed on the exterior surfaces (surely not every one lived in a smoker's house ?) Here's one that was left on my doorstep last week split only at the handle end...so far: |
Post# 146257 , Reply# 8   8/7/2011 at 22:06 (4,643 days old) by henry200 (Saint Paul MN)   |   | |
Why did Sears go to such an inferior hose? My aunt had a Kenmore Powermate cannister purchased in the 60's and the hose was still in perfect condition 30 years later when the vacuum was replaced. |
Post# 146260 , Reply# 9   8/7/2011 at 22:11 (4,643 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Post# 146528 , Reply# 12   8/10/2011 at 14:20 (4,641 days old) by kenkart ()   |   | |
Be sure to buy Scotch brand electrical tape, My Uncle has been an electrical contractor for over 50 years, and he says any other brand will indeed get sticky and shrink. |
