Thread Number: 13766
Kenmore and Panasonic Canisters |
Post# 146020   8/6/2011 at 09:46 (4,618 days old) by mark40511 (Lexington, KY)   |   | |
I have a QUESTION. I seem to remember reading somewhere here(?); Is it true that the Sears Kenmore (Panasonic made) canisters are more cheaply made than the same canisters by Panasonic. In other words, does Sears have Panasonic "cheapen" them more than their own canisters?
I don't even know if Panasonic still makes some Kenmore canisters or not. The canister I have is a Panasonic made by Kenmore. I'm contemplating getting another one but I might get the Panasonic instead of the Kenmore if this is the case. Thanks |
Post# 146041 , Reply# 5   8/6/2011 at 14:42 (4,618 days old) by mark40511 (Lexington, KY)   |   | |
Actually
I got my first Kenmore canister in 2004 when I bought my new house. I fell in love with it. It has got to be the easiest vacuum I have ever used and the suction if REALLY good and I like the PN a lot! But (for me at least) the SAME thing happens on EVERY stinking one of them that I have had. The quick disconnect at either the handle OR the wand OR the neck of the PN shorts out after about two to three years. Someone had told me that it was because when you use the quick disconnect that (if) you quick disconnect WHILE the power is on at the PN, it will ultimately cause a short. BUT I NEVER did this. I always had it on just suction when using quick disconnect. I guess I was hoping that perhaps Panasonic's would be a little sturdier as I recalled reading somewhere on this forum that some critical areas of the Panasonic's were better than Kenmore's. I don't know, maybe I dreamed it. Anyway. Here is a link to one I was looking at. For some reason, it is much cheaper on this site than anywhere else I've looked. I've seen it on some sites for 250 plus. The current Kenmore can I have is shorting in the hose handle. On the pull back using the PN, it's starting to (brown out) somewhat. I took the handle apart (takes five screws) and I saw the connection, but some wires go down into the collar of the hose and if I did buy a new switch, I have no idea how to get to those wires in the collar as they are not easily accessible at all. CLICK HERE TO GO TO mark40511's LINK |
Post# 146070 , Reply# 6   8/6/2011 at 20:34 (4,618 days old) by eurekaprince (Montreal, Canada)   |   | |
Post# 146135 , Reply# 7   8/7/2011 at 04:10 (4,618 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
Mark, do yourself a favor & keep your Kenmore, & just take the hose into a repair shop & have the PN receptacle in the hose replaced. If you buy the Panasonic, you will have the same problem again eventually....it's a design flaw that Panasonics/Kenmores have. From what you have told me before, that you replace them every few years, it sounds like your present Kenmore would still have plenty of life left.
Rob |
Post# 146137 , Reply# 8   8/7/2011 at 07:12 (4,617 days old) by eurekaprince (Montreal, Canada)   |   | |
Mark - that red Panasonic canister is a great machine. Highly rated by Consumer Reports and received a "very good" mark on bare floor cleaning, carpet cleaning and airflow through the hose for tool use. The best reason to get this canister instead of another Kenmore is the set of attachments you get: the newer Kenmores have a very odd set of attachments with a combination upholstery nozzle+dusting brush. Some of the more recent Kenmores have a very, very bulky handle with a bulky dusting brush permanently incorporated into the handle. This red Panasonic you are considering still has the normal, traditional set of 4 separate attachments hidden away under the cover of the unit. This is a much better design, in my opinion.
The only Kenmore power nozzle canister that has a really well-designed set of tools on the market now is that nifty blue Kenmore Innovation with the "cross-over" power nozzle which incorporates a bare floor brush. It is the top-rated pn canister in Consumer Reports testing, and comes with a very wide dusting brush and on-board mini power nozzle. Not sure what kind of upholstery nozzle it provides, but you can always buy the traditional Kenmore uphostery nozzle separately for about 10 bucks. |
Post# 146138 , Reply# 9   8/7/2011 at 07:48 (4,617 days old) by mark40511 (Lexington, KY)   |   | |
Yes it is a great machine, except for the connections going bad after a couple of years. I might get the hose fixed and just keep what I have. I was bored this morning looking on Ebay and some refurbished canisters that look to be as user friendly as the Kenmore I have. What do you guys think about the Electrolux Guardian? I'm sure it's not as well made as the old Lux's, but it has to be a better built machine than the Kenmore/Panasonic. It also looks like it has quick disconnect which I love. I saw one completely refurbished for 299.00
Will this last or are they known to have problems. Anyone ever used one? Thanks |
Post# 146170 , Reply# 10   8/7/2011 at 13:30 (4,617 days old) by bimmer740 (Long Island, New York)   |   | |
If you are going to get a Lux "R" style canister, I would recommend the Renaissance or Epic 8000 over the Guardian. I think the hepa filter cuts off to much of the suction on the Guardian models. The Epic 6500/Legacy machines have the same motor but they have a shorter cord, 21 ft versus 28 ft with the Renaissance type machines. The controls on the hose handle are great and the body seems more solidly constructed than the egg shell type Diplomat style machines. A Lux Classic or even the older Epic 6000, which each have older style metal wand setup, are also another great option.
Post# 146173 , Reply# 11   8/7/2011 at 13:46 (4,617 days old) by mark40511 (Lexington, KY)   |   | |
Hey Bimmer740
I haven't bought it yet. I was also looking at the Renaissance and another one. But didn't the Renaissance have major issues with the electronics I thought or was that corrected? I will post the two links of the two I'm looking at so far. I just want something that's canister, easy to use and will LAST Are you saying that the Renaissance doesn't even have a hepa filter? How do they filter? Just the bag? CLICK HERE TO GO TO mark40511's LINK on eBay |
Post# 146174 , Reply# 12   8/7/2011 at 13:46 (4,617 days old) by mark40511 (Lexington, KY)   |   | |
Post# 146187 , Reply# 13   8/7/2011 at 15:35 (4,617 days old) by mark40511 (Lexington, KY)   |   | |
I went ahead and bought the Renny after reading up on them and watching some youtube vids. I saw that it has an after filter under the attachments. The "R" bags are all over Ebay and they are much cheaper than the Kenmore bags, but interestingly enough, I didn't see the synthetic cloth allergen version of this bag, only paper. I hope I like it.
Post# 146188 , Reply# 14   8/7/2011 at 15:37 (4,617 days old) by kirbyloverdan (Egg Harbor Twp . NJ aka HOOVERLOVERDAN ❤️)   |   | |
after filter which is located under the tool compartment . It comes with the box of bags . They did have problems with the hose electronics thats why the changed to the slide button controls .They made the motor more powerful on the Hepa Guardians to compensate for the suction loss with the added hepa filter.
Post# 146267 , Reply# 15   8/8/2011 at 01:30 (4,617 days old) by bimmer740 (Long Island, New York)   |   | |
Dan, I wasnt aware that their was any change in the motor when the Guardian came out. I thought that Electrolux just carried over the previous motor from the Renaissance/Epic 8000, and added a HEPA filter to the top of the unit. The Guardian that I had for a very short time had less suction than my Renaissance does, or any other Electrolux canister I have ever owned. Maybe Im completely wrong, but I thought the only change in the Guardian motor occured with the release of the Guardian Ultra.
@mark40511: I dont think that a HEPA style synthetic cloth type bag exists for the Renaissance style machines. I have yet to find one but I really wish that one of the after market bag companies would manufacture one. Actually, I wish that Aerus would make all styles of their filter bags in a synthetic cloth as an upgraded option instead of just the standard paper bags. I've been using the Perfect PowerTeam HEPA bags in my other Lux canisters and there is a noticable increase in overall performance. |
Post# 146270 , Reply# 16   8/8/2011 at 05:07 (4,617 days old) by mark40511 (Lexington, KY)   |   | |
Post# 147384 , Reply# 17   8/16/2011 at 17:24 (4,608 days old) by bimmer740 (Long Island, New York)   |   | |
Post# 147723 , Reply# 18   8/18/2011 at 19:52 (4,606 days old) by mark40511 (Lexington, KY)   |   | |
It arrived in great condition (relatively speaking). I got a bucket of hot water and dish detergent and scrubbed EVERYTHING. As I was cleaning it, I noticed that it had a really solid feel to it. The hose and wands are longer than the Kenmore. I noticed that when vacuuming, there is NO GIVE when pushing or pulling (in the quick connections) as there was with the Kenmore. It runs well, has about as good of suction as the Kenmore did. I'm not sure I'm loving the bags as they feel really cheap and the fact that no company makes the poly bags for these kind of blows my mind. I do like how easy the bag change is and there is no way the bag would come off of this. I had the problem where my bag would actually slide off the collar (of the Kenmore) for whatever reason and I would unknowingly be vacuuming right into the bin.
After using it for a week the bags seem to be pretty good. It's really EASY to use. I'm happy with it. Since I have two cats I need something I can grab quickly to run through the house. I still use my Rainbow though : D . There is some confusion as to which aftermarket hose will fit the Renny. I see all kinds of brand new aftermarket lux hoses but none specify they can be used on the Renny. Even the Guardian (which to me looks almost exactly like the renny) other than the hepa filter, won't fit. Some have said it will fit, others say it won't. I emailed Aerus and they say it won't fit. Nothing is wrong with the current hose, but since I had heard of problems I wanted to see if there was an updated hose in case anything went wrong with this one. I mean, since this is the ONE machine that had major issues with the hoses one would think a replacement would be easy to find. It's not. Hopefully I won't even need a replacement. I've put it through it paces the past week and I see no sign of any issues (knock on wood) |
Post# 147789 , Reply# 19   8/19/2011 at 02:09 (4,606 days old) by bimmer740 (Long Island, New York)   |   | |
Mark, Im glad you like your Renaissance. I really wish someone would make HEPA bags for the machine, but I truely wish that Aerus brings this body style back one day and then makes their own HEPA-type R-bags. I know thats a long shot but I'm allowed to dream lol. As far as the regualr bags, if you can get a case of Genuine Lux bags for $50, thats not bad at all. I think about 7 or 8 years ago I paid around $75 for a case of 100 C-style bags at my Electrolux dealer. I believe I paid about $35 for a case of 24 R-style bags a few months ago. When you figure out the cost per bag, less than $1.50 each, I dont feel bad about tossing the bag every 3 to 4 weeks or as soon as I notice the slightest odor. The Renaissace isnt my main vacuum, I use the VacuFlo for most cleaning, and the Renny gets used in between or for quick pick ups.
As far as the hose, I dont know if there is an after market replacement for the Renaissance units. I think the only option is to purchase one directly from Aerus. But DO NOT under any circumstances try to use a hose that is not a Renaissance hose on your machine!! I remember hearing years ago from the vacuum shop and reading on the old vacuum forum that the newer hoses for the Epic 8000-Guardian will cause the computer board to short out if used on the Renny. If you are careful with the hose, I dont think you will have a problem. Besides your machine is a later model in the light gray color scheme, which had an improved hose over the original two tone dark gray unit, which is the machine that I own. You can see the difference in the handle controls in the picture of my unit, sorry its not the best photo because I took it with my iPhone. |
Post# 147795 , Reply# 20   8/19/2011 at 03:38 (4,606 days old) by mark40511 (Lexington, KY)   |   | |
Wow! That is darker than mine! So mine is a later model renaissance? Cool! Regarding the bags: The 100 count bags are generic 4 ply, not genuine. He included four of these and one micro filter (also generic) They seem to work good which is kind of shocking to me because they have the cheapest feel of any vacuum bag I've ever seen. I mean, the paper Kenmore micro lined DVC bags are much thicker feeling than these. I have no idea who makes these. They are brown and self sealing though. I haven't bought them yet. I think the 100 count genuine is 95 dollars, but someone told me that Lux didn't make their own genuine bags, that some other company made them for them; that they were no better than the generic.
I do notice that there are three speeds on the unit. If you're using the LOW speed suction and turn the PN on, the PN has much more power than when the unit is on high speed. Too bad it can't maintain that power on the PN when on full suction. I guess that's normal. I also like the fact that it has a blower on it. I know the vacuum shop I bought it from said it had been cleaned and tuned. I wonder what the definition of "tuned" is exactly in a vacuum. I've never heard of a vacuum being "tuned". Then again, I don't work on them : D |
Post# 147808 , Reply# 21   8/19/2011 at 10:09 (4,605 days old) by mark40511 (Lexington, KY)   |   | |
Well, it happened! The electronics in the hose are already starting to go. The seller is sending me another hose. Here's exactly what's happening. So I'm vacuuming and I'm pushing the PN under the bed and when I laid the wand almost flat against the floor to get way under the bed, the PN power shut off, I thought I accidentally hit the button, so I pushed the button and that turned the PN back on, it went off again. The main vacuum continued to run..In order for the machine to turn off you have to unplug it from the wall. The only thing that seems to work is the turning PN on and off. You can't change speeds. It stays on high speed. Too bad I already am having this issue because I love this vacuum
Post# 147814 , Reply# 22   8/19/2011 at 11:15 (4,605 days old) by whirlsonicmore (South US)   |   | |
Another part of the Renny's speed control circuitry also consists of a board inside the canister itself. |
Post# 147863 , Reply# 23   8/19/2011 at 17:41 (4,605 days old) by bimmer740 (Long Island, New York)   |   | |
Mark, Sorry to hear that the hose is giving you a problem already but, its great that the seller is sending you a new one! I feel like its one of those things that you just shouldnt talk about because you may jinks a good thing that you have going at the moment.
As for the bags, I've owned many Electrolux machines over the years, various uprights and canisters and I have always used Genuine Electrolux/Aerus bags in my machines. The way I see it, for me the price is right for the genuine paper Lux bags, so I wont switch to an after market bag since I have never had a problem with the bags themselves. The only non-Electrolux bags that I do use, not really after market, are the Perfect PowerTeam HEPA C-type bags. Obviously because they offer better filtration and airflow, overall a higher quality bag in my opinion. As for the power nozzle not having the same amount of power on all three speeds, you may be 100% correct. However I just finished using mine and I was thinking about what you said. I love that I can set the unit on "low" and use it on something like the small bathroom area rugs which are usually a real pain to clean since they have a rubber backing and get sucked up into most power nozzles. Anyway, I used my Renny on a dense wool area rug and played around with the motor speed. I may be wrong but I think that you may notice that the nozzle seems to have "more power" on a lower speed becuase there is less drag on the power nozzle motor. With greater suction the power nozzle seals itself more firmly to the rug (I have several very dense area rugs that are truely a PIA to vacuum, even my Diamond Edition is difficult to use on them with the TechDrive engaged) therefore creating more drag on the motor, hence it seems as though the motor is not moving at the same rate as it does on a lower speed (which it probably isnt, buts the motor isnt at fault). Again, this is just my own theory and I dont mean to discredit what you said in any way, but I never noticed any difference until you pointed it out, and in my own home I can attribute this change in power not to the machine but the rug itself. I hope your Renny is back up and running in proper order soon! |
Post# 147934 , Reply# 24   8/19/2011 at 21:17 (4,605 days old) by mark40511 (Lexington, KY)   |   | |
Post# 147941 , Reply# 25   8/19/2011 at 21:42 (4,605 days old) by mark40511 (Lexington, KY)   |   | |
This is the very aftermarket hose that there is some confusion by several people as to whether it will work on the Renny or not. Notice in their listing, it says Renaissance. I've contacted several sellers about this very hose. Half say it will work, and half say it will not work. I don't think this is the very LATEST guardian or 8000 styles hose, but the one before it. So I don't know
