Thread Number: 13589
1920's Royal |
Post# 144234 , Reply# 1   7/21/2011 at 15:47 (4,661 days old) by electrolux~137 ()   |   | |
Hammering motor parts is generally not a good idea...
Post# 144401 , Reply# 2   7/22/2011 at 23:53 (4,659 days old) by bvac6 (Fort Wayne, Indiana)   |   | |
Ive had this kind of problem with those Royals as well, the only suggestion I have for that would be to just gently work with it until it decides to cooperate. Keep manipulating it and wiggling it around and it will eventually work, patience is a must with old vacs as they can be contrary. As for the brush wires the glue should hold but I would recommend gorilla glue since it holds up to heat alot better (I used gorilla glue in my dishwasher and it has held up under the heat very well)
Post# 144537 , Reply# 4   7/23/2011 at 23:48 (4,658 days old) by bvac6 (Fort Wayne, Indiana)   |   | |
Well, if the armature is hard to turn on its own those bearings are going to need oil. I will have to check on my old Royal but im pretty sure there are oil ports where you can add oil to it. I think everyone recomends three in one oil. If you can oil, dont overdo it. Try a drop at a time to see if it frees up.
Post# 144580 , Reply# 5   7/24/2011 at 15:07 (4,658 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
