Thread Number: 13365
kirby lost a wheel!! |
Post# 142269   7/7/2011 at 17:19 (4,675 days old) by tommymilan (milano)   |   | |
Dera fellows,
I'm writing to you because today happened something I'd never expected: I was using of my almost brand new kirby g6 to clean the carpet and suddently the font wheel on the right came out while the Toe Touch control pedal assembly came out from its location making the cleaner unusable and spotting my white carpet with the crease coming out of the fallen pieces. the first thing I did was taking a hummer and push thing back into place but the assembly doesn't remain tight so the kirby continues to lose its fron wheels. I called a friend of mine, a Kirby repair center owner and he said he has to replace the whole weel axle and toe touch control asembly...50 eur for me. Has anything similar ever happened to any of you? My mother has been using in her house three kirbies ( one G5 and two G6) and she never had a problem like this. I am quite confused but ... Greetigs to all, Tommy From a very sunny and hot Milan, Italy |
Post# 142280 , Reply# 1   7/7/2011 at 19:44 (4,675 days old) by hoover1 ()   |   | |
never had a problem like that, you should call the kirby help line! |
Post# 142287 , Reply# 2   7/7/2011 at 22:39 (4,675 days old) by KirbyLover (Louisville Kentucky )   |   | |
Wow, weird! I would suggest finding some used parts, on ebay or something. |
Post# 143348 , Reply# 4   7/15/2011 at 14:23 (4,667 days old) by a007kirbyman (--->> Originally My Mom <<--- (now Wisconsin))   |   | |
"...anything similar ever happened..."
Hello Tommy. This does happen occasionally. If you'll notice the axle is 'splined' externally & the axle 'arm' that the wheel attaches to is 'splined' internally. The 'arm' is pressed onto the axle. Once it has came apart, it will almost guaranteed come apart again if you attempt to line it up & press it back on. Especially if it is used regularly. I may do two replacements of them w/in a week, & then go six months to a year or more w/o doing one again. Sometimes things seem to happen in 'bunches.' ~~lol~~ Front Wheel Shaft Assy 131606S $15.67 This is w/o the: Ratchet Lock Assy (which you shouldn't need anyway). If you are interested, please feel free to contact me directly. Cheers & hagr8wknd all, Bill |
Post# 143460 , Reply# 5   7/16/2011 at 11:39 (4,666 days old) by Craig_1982 (Newcastle Under Lyme (England))   |   | |
Hello Tommy,
I had the same problem a year or so ago on my Generation 4 and like you mine was the right hand side, I overcome the problem by removing the axle and adding the wheel back on making sure it was aligned properly so the Kirby would be sitting level then drilling a small pilot hole through both section's that had separated and adding a small self tapper screw and this seems to have done the trick but one day I will fork out the money and buy a new axle. |
