Thread Number: 13083
Golden J Repair Question |
Post# 139461 , Reply# 1   6/11/2011 at 17:05 (4,699 days old) by vacumaniac ()   |   | |
Pic 2 |
Post# 139499 , Reply# 3   6/11/2011 at 23:58 (4,699 days old) by vacumaniac ()   |   | |
Thanks so much for that info! |
Post# 139511 , Reply# 4   6/12/2011 at 07:42 (4,699 days old) by pnluxconvlvr (Georgia)   |   | |
Post# 139544 , Reply# 6   6/12/2011 at 15:44 (4,698 days old) by vacumaniac ()   |   | |
pic #2 |
Post# 139547 , Reply# 8   6/12/2011 at 16:11 (4,698 days old) by Crevicetool (GA )   |   | |
I can't tell in the picture, is there a corresponding mark on the brass lead? |
Post# 139548 , Reply# 9   6/12/2011 at 16:15 (4,698 days old) by vacumaniac ()   |   | |
Yes, on the junction block there is a small hole in the third area above the yellow wire. I was confused as to why the first two areas appear solid (ie no hole) it alomst looked as if something was missing.... |
Post# 139553 , Reply# 11   6/12/2011 at 16:27 (4,698 days old) by vacumaniac ()   |   | |
flange pic |
Post# 139582 , Reply# 13   6/12/2011 at 20:21 (4,698 days old) by goadie12 ()   |   | |
cant wait to see pics when it is done |
Post# 139583 , Reply# 14   6/12/2011 at 20:25 (4,698 days old) by pnluxconvlvr (Georgia)   |   | |
If by the off chance something did happen you could get a new corwinder and install the original gold outer facia onto it and just do a little rewire with connectors and a crimping tool. It is very interesting that my tanks even the identical same on the outside have differsnt connections on the inside. One has the "plug in" type as on yours and the other has male leads on the corwinder and female leads on wiring running from the front. So you could change it if you had to by drilling out the rivets and removing the connector mounted to the tank. The holes would not show because they are under the side bumper strip. :) Tyler
Post# 139589 , Reply# 15   6/12/2011 at 20:59 (4,698 days old) by pnluxconvlvr (Georgia)   |   | |
