Thread Number: 11801
I will ask YET AGAIN... |
Post# 126790 , Reply# 1   3/6/2011 at 16:12 (4,798 days old) by twocvbloke ()   |   | |
If you think the bearings sound bad, replace them or repack them, if it still sounds bad after that, then it's the carbon brushes/commutator or the brushroll... :) |
Post# 126796 , Reply# 2   3/6/2011 at 17:14 (4,798 days old) by vac_whisperer ()   |   | |
But can i still use it if the bearings arent that bad, but not in the best shape? VW |
Post# 126797 , Reply# 3   3/6/2011 at 17:31 (4,798 days old) by electroluxxxx (……)   |   | |
yes you can, just dont let it get too bad. |
Post# 126800 , Reply# 5   3/6/2011 at 17:40 (4,798 days old) by electroluxxxx (……)   |   | |
I second that David |
Post# 126842 , Reply# 8   3/6/2011 at 21:25 (4,798 days old) by vac_whisperer ()   |   | |
Okay, thanks. Now whats the best method to lubricate the bearings? VW |
Post# 126847 , Reply# 10   3/6/2011 at 21:49 (4,798 days old) by vac_whisperer ()   |   | |
So if youre just lubeing them, do you need the special bearing puller? And can you use WD40? VW |
Post# 126850 , Reply# 11   3/6/2011 at 22:17 (4,798 days old) by twocvbloke ()   |   | |
Erm, you already have the info on how to repack bearings, which I gave you: CLICK HERE TO GO TO twocvbloke's LINK |
Post# 126851 , Reply# 12   3/6/2011 at 22:20 (4,798 days old) by kittingerhoover ()   |   | |
You CANNOT use WD-40 which is a water displacement product. Replace the bad bearings, or have someone QUALIFIED do the work as to avoid damage. |
