Thread Number: 11776
Difference between TriStar CLX and DLX |
Post# 126602 , Reply# 1   3/3/2011 at 22:21 (4,773 days old) by eurekastar (Amarillo, Texas)   |   | |
I'm not positive about this, but I think they have the same exact vacuum motor. However, the difference is in the power nozzle. The CXL nozzle uses a flat belt and the DXL uses a geared belt. the DXL also uses a circuit board. The early DXL nozzle looks outwardly identical to the CXL nozzle. But at some point, Tristar updated its look. I have an early DXL nozzlewith the geared belt but I use it on my CXL (since I don't actually own a DXL).
Post# 126753 , Reply# 3   3/6/2011 at 10:38 (4,770 days old) by DKA-65 ()   |   | |
So the differences were with the power head and not the actual machine canister unit? ...and thank you for the info. |
Post# 126784 , Reply# 5   3/6/2011 at 14:34 (4,770 days old) by DKA-65 ()   |   | |
twocvbloke...Sorry about that, I had the post up from a few days ago and never hit refresh before I posted...So I never saw your reply. The one I have must not be the weaker motor. |
Post# 127734 , Reply# 7   3/17/2011 at 19:44 (4,759 days old) by DKA-65 ()   |   | |
Do you remember what motor you put in yours? or could the tapered fins be found/purchased and put on another motor? |
