Thread Number: 11701
Advice Needed on Electrolux 2100 |
Post# 125936   2/25/2011 at 15:30 (4,807 days old) by eurekastar (Amarillo, Texas)   |   | |
I've been visiting my Mom over the last few days, and she sent her old Electrolux 2100 home with me because the power nozzle doesn't work. When I arrived home, I hooked up my PN 1 to it and the PN 1 ran just fine. So I know the problem isn't with the hose or the hose switch. However, I need some advice regarding where to begin diagnosing the power nozzle's problem. I'm guessing the switch in the PN is tied to a circuit board. Could that possibly be the problem? Also, can someone tell me what years this model was manufactured? The vacuum runs really well. The motor sounds good and it has strong suction. I know very little about Electrolux vacuums, so thanks in advance for any help!
Post# 125941 , Reply# 1   2/25/2011 at 18:04 (4,807 days old) by Kirbylux77 (London, Ontario, Canada)   |   | |
It's just a solid-state switch. If you take the powerhead plug out of the sheath & try hooking it up directly to the receptacle in the hose & it works, then the powerhead cord in the sheath is gone & you will need to replace the sheath, about $20 at most vac shops.
If it is indeed the switch, then it is easy to replace, and it acts as the circuit breaker for the powerhead should a jam occur. Just disconnect the old switch & rewire the new switch the same as the old one & presto- one working powerhead! Rob BTW- This model started production around 1985-1986, and although I can't be certain when they stopped making it, my guess would be anywhere around 1989-1991. |
Post# 125949 , Reply# 3   2/25/2011 at 18:59 (4,807 days old) by eurekastar (Amarillo, Texas)   |   | |
The sheath cord tested out OK. So I removed the safety switch to examine it. I discovered that it comes apart pretty easily by prying up for prongs. The circuit won't close either because there is no longer enough tension on the spring or because corrosion is making it stick. So I think it just needs a new switch. I've seen a few on Ebay, so I may just order one.
Post# 125956 , Reply# 4   2/25/2011 at 21:32 (4,807 days old) by thevacuumman (Borger, TX)   |   | |
Mine is just like that one except mine has a blue PN-6 and i was told mine was from about 1987 |
Post# 125971 , Reply# 7   2/26/2011 at 07:23 (4,807 days old) by thevacuumman (Borger, TX)   |   | |
I have seen a couple of system 90's when I bought mine but I don't know for sure if the were purchased in the US or even released here |
Post# 126020 , Reply# 8   2/26/2011 at 14:43 (4,807 days old) by eurekastar (Amarillo, Texas)   |   | |
I went ahead and order the switch. I just hope I ordered the right one. The original switch had part # 938-41 stamped on it. It says it was made in Mexico too. I ordered the one in the link. It looks different and has part # 938-91, but I think it will work. Maybe the slight variation in part # indicates that it is made in China. LOL! I'll let everyone know if it works! The vacuum is fairly quiet, has strong suction, and pretty decent airflow too. So it shouldn't go to waste just because the nozzle isn't working.
CLICK HERE TO GO TO eurekastar's LINK |
Post# 126651 , Reply# 9   3/4/2011 at 17:36 (4,800 days old) by eurekastar (Amarillo, Texas)   |   | |
Well, the PN switch came in and just as I suspected, it wasn't an exact fit. So I had to do a little Southern Engineering and pull the guts from the old switch and slide the new switch into old switch's housing for stability. Maybe Electrolux engineers intend it that way? But the old switch cover wouldn't work because the new switch button is longer. So I left the old cover off. It doesn't look as good but it works.
Post# 126663 , Reply# 11   3/4/2011 at 19:25 (4,800 days old) by eurekastar (Amarillo, Texas)   |   | |
It was really bugging me that the switch cover wasn't fitting. So I took it apart again and refitted it. It worked this time! That model of Electrolux has surprisingly strong suction and airflow too. I can see why people like them. I put a generic brush roll on it too. The bristles seem to be stiffer than on the genuine Electorlux brush roll. Or maybe it is just because the older one became softer over time? Anyway, it seems to clean really well.
