Thread Number: 1099
For Spats, Hoover Convertible lower bearing maintenance |
Post# 11039   3/18/2007 at 17:27 (6,241 days old) by hoover1060 ()   |   | |
Ok Spats, here you go. You'll need a large and small flat screwdriver to do this. Get your Convertible taken apart down this far... |
Post# 11040 , Reply# 1   3/18/2007 at 17:29 (6,241 days old) by hoover1060 ()   |   | |
The speed switch is held in place by a small flat screw. Remove the screw and set it aside. |
Post# 11041 , Reply# 2   3/18/2007 at 17:30 (6,241 days old) by hoover1060 ()   |   | |
Lift up the speed switch and remove the motor mount screw that holds the speed switch bracket in place. This screw is the only motor mount screw that will have a little washer on it |
Post# 11042 , Reply# 3   3/18/2007 at 17:31 (6,241 days old) by hoover1060 ()   |   | |
This is what you should have: The screw and bracket, and the speed actuator(hockey stick) |
Post# 11043 , Reply# 4   3/18/2007 at 17:33 (6,241 days old) by hoover1060 ()   |   | |
At each corner of the motor...once free, grab the motor and pick it up like this |
Post# 11045 , Reply# 5   3/18/2007 at 17:34 (6,241 days old) by hoover1060 ()   |   | |
Flip the motor over gently |
Post# 11046 , Reply# 6   3/18/2007 at 17:35 (6,241 days old) by hoover1060 ()   |   | |
Now the fan will come off |
Post# 11049 , Reply# 8   3/18/2007 at 17:38 (6,241 days old) by hoover1060 ()   |   | |
Paitence here, do not force anything! Now that the fan is off clean under here thoroughly... |
Post# 11050 , Reply# 9   3/18/2007 at 17:40 (6,241 days old) by hoover1060 ()   |   | |
Is two spacer/washers, and a sleeve. The washers come off first, then pull the sleeve out. |
Post# 11060 , Reply# 13   3/18/2007 at 18:52 (6,241 days old) by scott55405 ()   |   | |
Jeff it appears your in the midst of restoring this cleaner's paint as well, but I notice the bag is yet another variation of the 1076/728 design. What model is this? |
Post# 11068 , Reply# 15   3/18/2007 at 21:24 (6,241 days old) by hoover1060 ()   |   | |
As Tom said, thats a full hood model U4007 from 1973. I chose that model because its the same as the one spats has, and had the questions about. |
