Thread Number: 10926
Eureka The Boss Smartvac |
Post# 118005 , Reply# 1   12/13/2010 at 16:58 (4,875 days old) by bagintheback (Flagstaff, Arizona)   |   | |
Post# 118027 , Reply# 3   12/13/2010 at 18:19 (4,875 days old) by vacman117 (Chicago, IL)   |   | |
Probably the best bagged vacuum you are going to find for its price range. As mentioned above, the air flow is great, along with its large fill tubes, and the dirt not having to travel threw the hose before entering the bag like most vacuums. I found a used one for $6 at a thrift store and I honestly couldn't be more impressed!
Post# 118031 , Reply# 5   12/13/2010 at 19:28 (4,875 days old) by eurekaprince (Montreal, Canada)   |   | |
Highly rated by Consumer Reports for at least five years.....ever since Eureka started making them. The only complaint they had was that it was hard to pull due to the way it grabs the carpet.
I love the fact that Eureka gives you proper "adult-size" attachments on board! They are actually the very same tools you used to get on the World Vac canisters. Love the separate classic Eureka dusting brush and upholstery nozzle - though I think the clips to hold the upholstery nozzle are too wimpy and if you don't store the nozzle properly, it can easily fall off. The dusting brush has a very secure little cubby hole though! Many people have complained that the brush roll on-off switch is hard to move and seems very prone to breaking. There seems to be a magical way to get it to shift into place but there is no hint given on the vac base to remind you how to set this properly (move switch with handle down, or handle up - not sure what the correct method is). Do other users have problems adjusting this switch? |
Post# 118048 , Reply# 9   12/13/2010 at 21:08 (4,875 days old) by gusherb (Chicagoland)   |   | |
Don't let the Smartvac fool you... It can't outclean my Sanitaire SC888, Kirby Heritage, or Hoover guardsman. But it does groom much better then all of those. |
Post# 118057 , Reply# 10   12/13/2010 at 21:59 (4,875 days old) by djkain2007 ()   |   | |
it could so outclean a kirby &/or a hoover but no idea on a sanitaire since i don't have anything besides 2 tristars |
