Thread Number: 10759
Royal Uprights - Rite-Hite or Au-Toe-Matic? |
Post# 116350   11/29/2010 at 05:29 (4,896 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
For all those of you familiar with Royal all-metal uprights: does anyone prefer the Rite-Hite screw-type height adjustment system, or the 5-position Au-Toe-Matic toe-touch height adjustment system?
The Rite-Hite adjustment system was until 1987 the only method of adjusting height on a Royal upright. Models 887, 361, 363, 381 and 383 (last four units are heavy-duty commercial models) were the first Royal metal uprights to use the Au-Toe-Matic toe-touch height adjustment system. Also, some Royal metal uprights with the Rite-Hite adjustor as standard could be specified with the Au-Toe-Matic system by adding an "F" at the end of the model number (e.g. 886F, 6103F). Likewise, some models with the Au-Toe-Matic as standard equipment could be specified with the Rite-Hite system by adding "RH" at the end of those model #s (e.g. 2075RH). From Royal's official website, those models with Rite-Hite proclaim "infinite" height settings. So, do you folks prefer the old-style Rite-Hite or the Au-Toe-Matic system? I also want to know if you have modified any of your vintage Royal uprights to use the Au-Toe-Matic, or vice-versa? ~Ben |
Post# 116375 , Reply# 2   11/29/2010 at 14:23 (4,895 days old) by scvacuumguy (SC)   |   | |
Post# 116401 , Reply# 3   11/29/2010 at 16:29 (4,895 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 116405 , Reply# 4   11/29/2010 at 17:08 (4,895 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
For all those of you unfamiliar with the Rite-Hite, here are the official steps as taken from a Royal instruction manual:
TO ADJUST THE NOZZLE ON MODELS WITH "RITE-HITE" ADJUSTOR KNOB: 1. Turn the Rite-Hite knob (located above rear wheels) counter-clockwise to raise the nozzle off the carpeting. 2. Turn on the vacuum cleaner. Use the finger switch conveniently located on the handle. Push down to start - up to stop. 3. Now, gradually turn the Rite-Hite knob clockwise to lower the nozzle to the carpet. (Common practice involves that once you adjust the knob low enough that the nozzle - and especially the revolving brush - begins contacting the carpet, try to adjust the height knob one more turn clockwise). On models also with Adjust-O-Rite, the stub should be flush with the plug as a means of indicating correct height adjustment. ~Ben |
Post# 116430 , Reply# 6   11/29/2010 at 21:22 (4,895 days old) by truckerx (Palm Springs, CA)   |   | |
Post# 116444 , Reply# 9   11/30/2010 at 06:49 (4,895 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 116445 , Reply# 10   11/30/2010 at 07:27 (4,895 days old) by kenkart ()   |   | |
It was burgandy trim, can't remember the model. |
Post# 116447 , Reply# 11   11/30/2010 at 07:33 (4,895 days old) by eurekastar (Amarillo, Texas)   |   | |
Post# 116496 , Reply# 13   11/30/2010 at 16:17 (4,894 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 117022 , Reply# 14   12/5/2010 at 05:29 (4,890 days old) by hygiene903 (Galion, OH)   |   | |
Post# 117832 , Reply# 15   12/11/2010 at 20:03 (4,883 days old) by djtaylor (Salt Lake City, Utah)   |   | |
