Thread Number: 10108
My sad Kirby Heritage II |
Post# 109765 , Reply# 1   9/29/2010 at 19:43 (4,928 days old) by eurekastar (Amarillo, Texas)   |   | |
Is it the screws on the bell housing that you're having trouble with? If the screw heads aren't already messed up, you might try gently tapping them with a small hammer and then see if they'll unscrew. If you have a soldering iron, you can also try heating the screws and then letting them cool off before trying a screw driver. If that doesn't work, then you might want to buy an impact driver. Then of course, there's WD40. That would be a slow process and you'd have to find ways to brace the motor unit so that the oil will penetrate and not simply drip off. If the screw heads are messed up, then you'll to try a screw extractor. Screws that are frozen in place can be a huge headache!
Post# 109766 , Reply# 2   9/29/2010 at 19:48 (4,928 days old) by eurekastar (Amarillo, Texas)   |   | |
Post# 109778 , Reply# 5   9/29/2010 at 20:39 (4,928 days old) by eurekastar (Amarillo, Texas)   |   | |
Post# 109786 , Reply# 6   9/29/2010 at 21:38 (4,928 days old) by motojoejo (MO)   |   | |
Yep!!! I'm still learning the terms- but I'm gladly not using the term dohickie and thingywhaty. I can get to the motor but not open the motor or get to the fan. |
Post# 109826 , Reply# 7   9/30/2010 at 08:09 (4,927 days old) by eurekastar (Amarillo, Texas)   |   | |
You'll have to remove the screws from the front a rear of the fan case in order to open that up. Do you have a drill with screw bits? Sometimes the torque from a drill helps in such cases. But try gently tapping on the motor housing screws and then use a screwdriver. Be careful not to mess up the screw heads!
Post# 109907 , Reply# 9   9/30/2010 at 22:39 (4,927 days old) by eurekastar (Amarillo, Texas)   |   | |
Post# 109929 , Reply# 10   10/1/2010 at 12:17 (4,926 days old) by motojoejo (MO)   |   | |
Completely rusted almost to a point the screw driver will not fit |
Post# 109961 , Reply# 11   10/1/2010 at 20:59 (4,926 days old) by eurekastar (Amarillo, Texas)   |   | |
Post# 110178 , Reply# 12   10/4/2010 at 09:00 (4,923 days old) by motojoejo (MO)   |   | |
I tried as suggested but the first screw acted like it was breaking instead of loosening so I left it alone. I think it has come to the point of being roached and unfixable. |
Post# 110206 , Reply# 13   10/4/2010 at 12:37 (4,923 days old) by eurekastar (Amarillo, Texas)   |   | |
It was definitely left in a damp environment! You might try more WD40 and continue reapplying it for a few days to let as much of the oil penetrate into the threads. You might also try heating the screws with a soldering iron. That will cause the metal to expand and as it cools, it will contract and hopefully break loose some of the ruse. I've never tried that with a screw in plastic though and I don't know how much heat those plastic housings can take. They should be able to take a good amount since the motor generates heat.
